Salta al contenuto principale
The phone comes with a 6.50-inch touchscreen display offering a resolution of 720x1600 pixels at a pixel density of 269 pixels per inch (ppi) and an aspect ratio of 20:9. Oppo A53 2020 is powered by a 1.8GHz octa-core Qualcomm Snapdragon 460 processor. It comes with 4GB of RAM.
Phone is in recovery mode
Phone recovery mode
Not starting server says selecte the language and other things
Questa è una buona domanda?
Punteggio 6
Aggiungi un commento
4 Risposte
Risposta più utile
This issue can occur due to software glitches, failed updates, or accidental button presses.
Here are some possible solutions:
Solution 1: Restart the Phone
  1. Press and hold the Power button for about 10-15 seconds until the phone turns off.
  2. Turn it back on and check if it boots normally.
Solution 2: Exit Recovery Mode
  1. In Recovery Mode, use the Volume buttons to navigate.
  2. Select "Reboot System Now" using the Power button.
3.If this doesn't work, try "Exit Recovery Mode" (if available)
solution 3: Wipe Cache Partition
  1. In Recovery Mode, select "Wipe Cache Partition".
Confirm the action and restart your phone.
Solution 4: Perform a Factory Reset
  1. In Recovery Mode, select "Wipe Data" or "Factory Reset".
Solution 5: Use ADB Commands
*If your phone is still stuck, you can use ADB [Android Debug Bridge] via a computer
Punteggio 1
Thỉnh thoảng điện thoại của mình bị màn hình chờ kiểu mây bay, không biết làm sao để hiển thị các icon trên màn hình
Vietnamese -> English translation:
Sometimes my phone has a floating cloud screen, I don't know how to display the icons on the screen
Punteggio 0
My phone's FRP is locked, please unlock it.
Punteggio 0
My phon otometik band hota he
Punteggio 0
Aggiungi la tua risposta
Manish PAHADE sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 32
Ultimi 30 giorni: 142
Tutti i Tempi: 1,580
