Salta al contenuto principale
Il visore per realtà mista Meta Quest 3S è stato rilasciato il 15 ottobre 2024 ed è un fratello minore arrivato dopo il Meta Quest 3.
How do I fix my stick drift?
I’ve had my Meta Quest 3s since December 31st. Its August 21st as of this being posted, It’s been about a week and i’ve had really bad stick drift issues, especially on my right controller. i’ve tried to recalibrate and clean my controllers, like the official guide says, but i’m still met with issues. What can I do without completely replacing my controllers? help!
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
3 Risposte
Risposta più utile
What kind of alcohol did you use when cleaning them? If it's not 90% you won't get the result you want. Can you give me more details about the issue?
Punteggio 2
1 Commento:
In terms of the alcohol i probably didn’t use 90%. unfortunately i don’t remember. i mean, the drift isn’t constant, however, i’m finding that after about a half ish hour of using my headset with the controllers, the drift persists after that. I stopped using it for about two months, came back to it yesterday, and nothings fixed it. i cleaned it again thoroughly changing the batteries and AGAIN, recalibrating the controllers. i guess i’m kind of stuck now. I’ll see if the 90% helps though! thanks!
da Condividi
So on my quest 3s left controller when I use a certain move on the thumbstick,example going backwards it just doesn’t let me go back same thing with the other direction that are provided to use in order to move.ive used alcohol wipes even my mouth to blow air out but nothing works so this is my answer
Punteggio 1
3 Commenti:
Watch youtube video "3 способа исправить дрифт стика на Oculus Quest 2".
I've used method2 but without disassembling. It helped
da Condividi
Thanks guys! Update: My stick drift has gotten.. worse. 😭. My friends are telling me I can use compressed air to clean them or, ultimately, replace them. But that is NOT happening anytime soon. Trial and error, I'll see what the video can do to help me.
da Condividi
@alexanderpakizh I don’t understand that language
da Condividi
how to fix my 3s vr
Punteggio 0
Aggiungi la tua risposta
carousel0w sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 41
Ultimi 30 giorni: 168
Tutti i Tempi: 3,204
