Salta al contenuto principale
The Honda GX25 is a 25cc, four-stroke, single-cylinder, overhead camshaft engine that produces approximately 1-horsepower at 7000 revolutions per minute.
Oil and fuel ratio
Do I mix the fuel with 4 stroke oil? If so what’s the ratio ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
@darinw11624 it's a four stroke engine. You do not mix the fuel since a 4 stroke engine has a dedicated oil reservoir. Your GX25 engine uses regular unleaded gasoline and does not require any fuel/oil mixing
Punteggio 0
Aggiungi la tua risposta
Darin W sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 34
Tutti i Tempi: 178
