Salta al contenuto principale
Socket from battery accidently removed
Hi, hope somebody can help me.
I installed an SSD drive in my MacBook air. During installation I removed the battery and accidentally pulled the socket -not sure if it is the right term for the part - from the board instead of pulling the connector out. I did not use any force it came off very easily.
Now I have problems connecting the battery. I tried to put the socket back on the board, but somehow it seems loose and there seems to be no contact.
With AC it works fine, but the MBA does not recognize the battery. How can I fix it? Is there a replacement socket I can order?
Thanks in advance.
Matt
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Take a look at the photo on the right and try to tell us just what you pulled out. Did the wires come out of the socket? Sostituzione batteria MacBook Air modelli A1237 e A1304
Punteggio 3
3 Commenti:
Thanks, that is a good idea.
Photo - step 3, is showing how to remove the battery the right way by pulling out the connector. I pulled accidentally both parts from the board, the "socket" is still on the connector, but I can remove the part. Thanks for taking the time.
da
Did this fix the problem?
da
No, the socket is off. I took it to my neighbourhood repair store, which specializes fortunately in Apple. The gentlemen over there told me that he has to phone around to see if somebody does repair on a component level.
da
You may be able to resolder the socket in place.
Punteggio 0
1 Commento:
Thanks, Josh. I will look into that.
da
hi there,
i had the same problem. i have just resoldered it, with new problems following. the touchpad and the keyboard just works temporarly.
now looking for solutions to solve it
Punteggio 0
Aggiungi la tua risposta
Matthias sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 891
