Salta al contenuto principale
Msi pro b760m-a wifi ddr4 how to replace CMOS battery
I want to replace battery and wnat to buy which one battery
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi @kingsam
Here's the user manual.
Go to p.39 to see how to remove/replace the cmos battery.
Punteggio 0
4 Commenti:
But there is an iron plate stuck
da
@kingsam
Post an image of the motherboard showing where the cmos battery is and the plate.
Here's how to do this in ifixit Aggiungere immagini ad una domanda
da
Ok i upload the image tq
da
@kingsam
That is a heatsink over the IO (Input/Output) IC chip
It's either held on by clips (I can't see any in the image) or it is screwed onto the motherboard
If the motherboard is still in the case you may have to remove it from the case and then unscrew the heatsink from the underside of the board.
Usually the cmos battery model or part number is on the battery itself.
use that information to find suppliers
da
Risposta Più Utile
For those finding the CMOS battery on b760m-a, it is right under your display card not inside the heatsink! I cut my finger when trying to reach under the heatsink!!
Punteggio 1
Aggiungi la tua risposta
king sam sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 72
Ultimi 30 Giorni: 264
Tutti i Tempi: 3,256
