Salta al contenuto principale
Released April of 2019. Model number: SP315-51-757C Fully rotatable, touch-screen, laptop by Acer.
How to I fix my laptop battery
my battery cannot work my laptop turn off automatically without any alert and i think it is battery issue so how can i resolve it
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @hanzlahassan
Connect the charger to the laptop and fully charge the battery and then turn on the laptop. Leave the charger connected to the laptop so that the laptop stays on.
If Win10 is installed, when the laptop has fully booted, create a battery report
When you have the battery report, compare the Design Capacity value versus the Full Charge Capacity value of the battery as seen in the report. For a good battery they should nearly be the same value.
You can work out the condition of the battery as a percentage by using the formula Full Charge Capacity value x 100 ÷ Design Capacity value. If the battery percentage is <35% consider replacing the battery.
Here's the ifixit Acer Spin 3 SP315-51-757C Battery Replacement guide that shows how to replace the battery.
Search online for AC14B8K battery to find battery suppliers that suit you best. (supplier examples only)
Punteggio 1
Aggiungi la tua risposta
hanzla hassan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 19
Tutti i Tempi: 111
