Camera's battery latch broken and it won't turn on.
Questa è una buona domanda?
@mehtabsing76021 you will need to try to replace the screws that hold the cover to the mechanism. If that does not work, it is possible that the screws no longer properly hold. In that case, replacing the plastic cover should fix this. This Sostituzione contatti batteria della Canon PowerShot A720 IS should be identical to your camera.
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 6
Tutti i Tempi: 308
