Salta al contenuto principale
Rilasciato il 20 Settembre 2019, il Nintendo Switch Lite è una versione più economica e solamente portatile della console Nintendo Switch, dispone di controller Joy-Con integrati e di uno schermo leggermente più piccolo.
Right thumbstick still drifting after replacement.
So I replaced the right thumbstick due to extreme upward drift. The new one keeps having the same issue. I've tried 3 different sticks and they have the same issue. Could there be something else causing this. Calibration was done already.
Questa è una buona domanda?
Punteggio 0
1 Commento:
Hi Alex!
Okay, so only the right joystick is having issues at the moment? Can you share some pictures with us? Everyone is up to date I presume? Could still be motherboard related.
da
Aggiungi un commento
1 Risposta
Try cleaning the ZIF connector and check the motherboard for corrosion. Could be those problems, since I’ve encountered them myself. Had a piece of goo or whatever it is stuck in the ZIF connector and caused my joystick to drift downwards even though I calibrated it. The solder might have disconnected for some reasons as well, so I would suggest you to check the whole area for any kind of damage.
Punteggio 0
Aggiungi la tua risposta
Alex Schneider sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 102
