Salta al contenuto principale
Rilasciato il 20 Settembre 2019, il Nintendo Switch Lite è una versione più economica e solamente portatile della console Nintendo Switch, dispone di controller Joy-Con integrati e di uno schermo leggermente più piccolo.
Blank Black Screen Remains After Restart By Common Button Combinations
My spouse's Switch Lite screen suddenly went dark in the middle of them using it. I've troubleshot the SL using all of the common button combinations to restart it (power; power + volume up; power + volume down; power + both volume keys; power + Home) but the screen remains black.
I can't see what I'm doing on the screen but forward, back, and Home actions are completed normally based on the system sounds. Am I looking at a dead screen or could it just be something that's come loose inside the SL's body?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @heche
With the the console turned on and no display, try shining a flashlight at an angle close to the screen and check if you can see any images at all.
There will be very faint if they are there so trying this in a darkened room may help.
If there are images seen then there a backlight problem with the screen. Either the backlight power supply on the motherboard or with the backlight circuit in the screen itself. Here's a video that may be of interest. The problem in this case was a faulty IC on the motherboard. See from ~22:50 minutes in what the problem was in this particular instance.
If there are no images seen then it could be a loose video cable connection on the motherboard, a faulty screen or a faulty motherboard. Given that other functions work OK a faulty motherboard is the least likely problem.
Here's the ifixit Nintendo Switch Lite repair guide that may help to gain access so that you can check.
Punteggio 1
Aggiungi la tua risposta
Heche sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 54
Tutti i Tempi: 264
