Salta al contenuto principale
The Ryobi Pressure Washer RY14122 is a residential electric washer used for cleaning tasks around the home such as driveways, decks, and windows. This page provides detailed information and repair guides for this 1,700 PSI capacity washer that operates on a 13 AMP motor, includes a 0.6-gallon detergent tank, and has a 25 ft high-pressure hose.
Removing hose from spray gun and pump housing
How do you remove the spray hose from the spray gun and the pump housing? Rubber gaskets seem to be frozen on place. I don't what to force it and possibly damage something. I'm missing something.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @charleswmcilroy
Here's a video that shows how to remove the high pressure hose from the spray gun and the machine.
If the hose needs replacing search online for 308835065 to find suppliers that suit you best. (examples only)
Punteggio 1
Aggiungi la tua risposta
Charles W McILroy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 20
Tutti i Tempi: 215
