Salta al contenuto principale
Rilasciato il 20 Settembre 2019, il Nintendo Switch Lite è una versione più economica e solamente portatile della console Nintendo Switch, dispone di controller Joy-Con integrati e di uno schermo leggermente più piccolo.
I installed the new hall effect joysticks and now I have stick drift.
I followed the video to swap out my factory sticks with the hall effect sticks and now my right stick has some drift. I thought the sticks weren't supposed to have drift. Is my stick defective?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hi!
The Switch Lite is using different joysticks. Are you sure it's meant for the Nintendo Switch Lite..? If yes, do you have some photo's for us regarding the sticks?
Anyway, if it's meant for another controller or device, it's most likely you need to solder them in. If any trace or solder pad is damaged while (de)soldering it could still make the joystick drift. Please share some pictures with us regarding the solder work if you did solder.
Thanks in advance!
Punteggio 2
Hello! One of the mistakes that my friend made was, after swapping the joysticks out, he didn't calibrate the joysticks.
This can make the joysticks "drift" when they are just giving the incorrect readings.
use this guide to calibrate them!
https://www.youtube.com/watch?v=ejzWJ-UL...
Happy iFixing! :3
Punteggio 1
Aggiungi la tua risposta
Runtus_Maximus sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 28
Ultimi 30 Giorni: 134
Tutti i Tempi: 1,803
