Salta al contenuto principale
La versione rilasciata nel maggio 2020 del MacBook Pro da 13" si caratterizza per i processori quad-core Intel i5 e i7 di 10ª generazione e per la grafica integrata Intel Iris Plus (modello a2251/EMC3348 con quattro porte Thunderbolt 3).
Why are there green/red pixels all over my MacBook Pro screen?
There are small green/red and sometimes blue pixels scattered over the center of my screen (mostly green). How do I fix this? Is it a problem with the screen, graphics card, etc.?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
This appears to be a noise issue within the display. I’m assuming an external display doesn’t have any issues with the signal.
Did the system get wet at some point? Or suffer trauma like a bang or drop which damaged the hinge area of the display.
You likely need a new display assembly MacBook Pro 13" (A2251, 2020) Display Assembly and here’s the guide Sostituzione schermo MacBook Pro 13" 2020 4 porte Thunderbolt
Immagine Replace a display compatible with a 2020 model A2251 MacBook Pro 13" Four Thuderbolt Port laptop. Includes the 2560 x 1600 13.3" Retina LCD Screen, Display Cover, Bezel, FaceTime HD Camera, and Clutch Hinges.
Prodotto
$494.99
Punteggio 0
Not the best picture but it could be the coating on the display MacBook have a film on them i believe it's for anti reflection, anyway that coating can rub off, check if those dots are still on when the display is off if they are then it's that most likely.
Punteggio 0
2 Commenti:
IF the coating is indeed a bit 'hazy' then he is a guide I made on how to freshen it up MacBook Pro Retina Display Anti-Glare Coating Clean Up Technique
da
@alistairmoran - If you look carefully you’ll see these are discrete image blocks not a coating issue. If you remember the old days of an analog TV if you ran a vacuum near by the screen would react as the vacuum motor were often electrically noisy! Creating a similar effect.
da
Aggiungi la tua risposta
Junaayd Shaikh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 22
Tutti i Tempi: 144
