Salta al contenuto principale
Repair guides, disassembly, and troubleshooting information for the 2020 Mac mini with Apple's M1 chip. Identified by model number A2348.
17 Domande Visualizza tutte
AC2 "Unexpected device state 'DFU' expected 'RestoreOS'" Error 4014
My mac mini has sadly been rendered unbootable after a power surge. It will chime and immediately turns to an SOS blinking amber light.
As a disclaimer, I know this may be a hardware issue and that is why I am here. I have already taken it to Apple and they had no luck, telling me it needs a logic board replacement. It wasn't worth the money so this has turned into just a slow learning project that I've been chipping away at as a hobby.
I have tried to restore it with Apple Configurator and another MacBook, but after putting it into DFU mode and waiting for it to restore, it fails with this error (4014)
AC recognizes the Mac Mini, and the restore works up until Step 4/4, "Installing System", where it pauses halfway and then gives that error.
At that point I can see via the status light on the Mac Mini that it goes from a normal boot (white) to DFU mode again (solid amber) randomly, and AC sort of flickers at this point as well and then complains about the Mac Mini being in DFU (instead of RestoreOS).
I guess this could be something fried on the board, but I wouldn't know where to start because the only apparent issue being that it just randomly dips out of RestoreOS and back to DFU is very odd.
I've heard this error (4014) can be a faulty cable, but I've tried a lot of different ones, including a genuine Apple USB-C cable. I may buy a brand new one and try again.
Do you know of any software or hardware issues this could be? It seems like a simple issue but with no real rhyme or reason to it. Even if you just have a hunch, any tips on where I should look next would be greatly appreciated.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
I can’t say for sure but it does sound like the Flash chips got corrupted so the low level and OS is not recognized. As you are able to enter into DFU the system is mostly working (SoC).
Punteggio 1
Aggiungi la tua risposta
Kanen Stephens sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 38
Ultimi 30 Giorni: 108
Tutti i Tempi: 246
