Salta al contenuto principale
Il cippatore Bluebird CH400 è un biotrituratore commerciale a benzina da 13 cavalli con motore Honda GX390. Il CH400 può cippare rami o tronchi fino a 10 cm di diametro.
Bluebird chipper with a KOHLER engine not a Honda
We have a bluebird with a kohler 13 horse engine not a GX390 and cant find the parts for it I need. is there a cross reference for it somewhere.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta più utile
Hi @troyn,
Just verifying that it is a 13hp Kohler engine and not a 14hp Kohler engine?
There's a Bluebird with a 14hp Kohler - model number is CH400K. The CH440 is the Honda engine model.
Here's the user manual that may help.
The Kohler engine model is # 968160040 and the Honda engine model is 698160041 in the manual.
There's a parts list at the end of the manual.
If it is the correct one, for a part search online for Bluebird (insert part number) to find suppliers that suit you best.
If it's not the correct one, apologies.
Punteggio 1
Many of those knockoff engines are based on older battle-tested Honda designs, known as "Chonda engines"; even the Predator (HF) engines are clones of the Honda engines. Look up the engine part number and then look around to see which Honda motor Kohler cloned -- that will be your best bet to find the parts you need.
Punteggio 1
2 Commenti:
Hi @nick
Looks like we've got it covered both ways.
You read it as looking for Kohler engine parts and I read it as looking for Bluebird chipper parts.
Cheers
da
@jayeff As long as we know the engine model specifically called out as the type on that, that will be what you use to find out. But usually it's a clone of the Honda GX engines. The CC is how you figure it out.
da
Aggiungi la tua risposta
Troy N sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 21
Tutti i Tempi: 374
