Salta al contenuto principale
Seconda generazione di iPhone. Modello A1241/8 o 16 GB di memoria/plastica posteriore bianca o nera. La riparazione è più semplice rispetto al primo iPhone. Richiede l'uso di cacciaviti e strumenti di leva e distacco con ventose.
1158 Domande Visualizza tutte
home button not working after back cover replacement.
Hi there,
I replaced the back cover on iPhone 3G 8GB. Followed all the instructions. Everything works,except the home button which is nonresponsive.Reconnected all 6 cables and checked the ground connection of the main board. Nothing loose there. I wonder what is the problem.
Questa è una buona domanda?
Punteggio 1
2 Commenti
The front is all the way down ito it's housing, moreover, I left up the front half way and turned the phone on and tried to use home button while pressing it from beneath, it still didn't work. Thanks,
da
I got the same problem and would like to know wether anybody of you got a solutio for the problem...
I replaced just my back cover now my home button is not working...
da
Aggiungi un commento
7 Risposte
Risposta Più Utile
On the iPhone 3G, the home button makes contact when the top display is pushed in the whole way. Could it be that the front is not pushed in the seal all the way? Or is something obstructing the connection?
Punteggio 2
The console of the mic & speaker is probably below the metal ring(case) around the phone, so the home buttoncontacts cannot touch the motherboard below.
Open your iPhone again, and make sure that the two lower screws (mic&speaker) are first through this console, and than through the metal ring(case). To repair this, you need to unscrew all three screws of the console.
Hope this works for you (worked here a few times already)!
Regards, Pim
Punteggio 2
Since this is poorly documented on the web I thought I would chim in. I'm having the same problem since disassembly. After reading the last post I noticed there are two gold pin contacts just to the left of the home button if looking at it from under the screen board. Those need to contact two silver contacts on the console/sound board at the bottom of the phone. On mine after I replaced the back cover I notice the chrome trim is not sitting flash with the backing anymore, so its probably to high to make contact. I think I'm going to have to add a bit of solder to the contacts on the sound/console board to make sure it makes contact.
Or actually I just figured out what the problem is. While taking it apart I noticed that Apple used a very tacky type of glue to bond the chrome trim to the backing. There was a bunch in the slots for the very small tabs at the bottom of the backing. I bet just super gluing the chrome to the backing will fix this. Gel or another kind of semi permanent glue is best in case you need to tear it apart again.
Punteggio 0
I had the same issue. I disassembled my 3GS to clean off the dust behind the glass screen, and when I put everything back together correctly the Home button wouldn't work.
It turned out to be a problem between the silver contacts on the screen side near the Home button not touching the gold contacts on the bottom portion of the phone. I'm not sure why it worked before and not after disassembly, but here is how I fixed it. On the screen side, the silver contact strips are on a small piece of plastic that can be lifted slightly. I then put the end of a toothpick underneath the silver contacts and very slightly bent the ends back so that the middle would stick out more. I also rolled up a very small piece of paper towel and put it behind the middle of the silver contacts to help support and provide additional pressure when the phone was pressed together.
Now works perfectly!
Punteggio 0
i have snapped one of the connectors on the mobile(battery side) dont blame myself when i opened the phone it was clearly a refurb v.dusy found a random screew and the home botton connectors were sticking ip when i touched then one snapped too easy where can i buy these gold connectors
Punteggio 0
1 Commento:
if you mean the gold contacts on the back of the home button (screen side) then you need to buy a home button flex..try ebay. if you broke the contacts inside the iphone on top of the dockconnector then you will need to replace the dock connector.
da
Same issue after reassembly. I tried prying up the gold connectors (display side) twice, then I tried unscrewing the three screws holding down the plastic plate (battery side) a bit. The last act proved successful. It seems that these screws shouldn't be tightened too much after reassembly as this prevents the contacts from connecting.
Punteggio 0
hey wonderful adam i owe you a beer i messed with this phone for hours lifted it up like you said put small paper under boom i got home button man i would never thought of that im spending sll night trying to get the password off my new iphone cant do nothing no home button to put it into dfu recboot sucks take it easy
Punteggio 0
Aggiungi la tua risposta
monir sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 10,407
