Salta al contenuto principale
L'aggiornamento di marzo 2015 del MacBook Air 13" di Apple ha processori di quinta generazione Intel Core i5 e i7, risultando in una migliore performance e maggiore vita della batteria.
It won’t power on, so I replaced the battery, and still nothing
I know this is an old post, but I am having the same issue with my MacBook Air 13” early 2015 A1466, model. It won’t power on, so I replaced the battery, and still nothing. I have unplugged the I/o cable to see if it would power up, and no luck. I have a new I/O board being delivered soon. Do you think that can fix the issue? Also, the light is not on the MagSafe charger, when it’s connected. The charger is ok, because it works on other devices. Any help is greatly appreciated!
Questa è una buona domanda?
Punteggio 0
1 Commento:
@iphonefantik - I’ve spun your question out as the question you posted in is too confusing to use as a reference point as this person issues where all over the place What’s my issue: I/O Board, I/O Board Flex Cable or Logic Board? and besides the 2014 is a bit different from 2015 model.
da Condividi
Aggiungi un commento
1 Risposta
Let’s start off with everything connected properly internally are you able to get a lit MageSafe cord LED? Amber or Green, or dim Green.
Punteggio 0
Aggiungi la tua risposta
Rachel Kelley sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 20
Tutti i Tempi: 213
