Salta al contenuto principale
9th generation Honda compact car.
Life of a battery in an unused remote key
The battery in the remote key I was using has almost run out. The unused battery in the matching remote key won't work. Does an unused battery also lose energy after 5 years?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @jeanlfernlund
The shelf life of a Lithium coin cell battery is ~10 years, if stored at normal room temperatures.
All batteries lose a bit of power over time so whilst it should work perhaps it won't work for another 5 years.
If you have a DMM (digital multimeter) check the voltage of the battery. It should measure 3V DC. If it is <2.5V DC then perhaps the key won't work
Here's the Sostituzione batteria chiavi Honda Civic 2012-2015 guide that may help.
Punteggio 1
Aggiungi la tua risposta
Jean L FERNLUND sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 89
