Salta al contenuto principale
The NV360 model is part of the Lift-Away Navigator Series and can be identified with its global trade item number 00622356533225. It is a lightweight 2-in-1 Lift-Away upright vacuum with a detachable canister for portable cleaning power.
1st power press does nothing, 2nd setting spins brush but no suction
When I turn on the vaccum no light or bare floor suction. When I press for brush, the brush spins but no suction.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Any more back ground to what may have caused this short circuit? Water, hit something, overheated,
Punteggio 0
A few possibilities;
  1. The local breaker is tripped or bad - if there is one - require a push to reset or new breaker.
  2. The switch is bad - requires new switch
  3. A connection has come loose or been corroded - it is not passing electricity - typically spade connectors - they must be very tight.
  4. A thermal cutout in the motor - Usually can't be replace - new motor
  5. the motor is bad - new motor
Punteggio 0
Aggiungi la tua risposta
Martin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 90
