Salta al contenuto principale
Rilasciato il 20 Settembre 2019, il Nintendo Switch Lite è una versione più economica e solamente portatile della console Nintendo Switch, dispone di controller Joy-Con integrati e di uno schermo leggermente più piccolo.
Black screen but has sounds
Hello, I'm having issues with my Switch Lite's LCD screen turning on. I can hear sounds, but I can't see anything. I even got a replacement screen in case it was the screen, but nothing changed. Can I please get any suggestions? Thanks.
P.S.: This was caused by my younger brother pouring water on it to "clean it." I feel like the main board is chalked.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi!
It more sound like there is corrosion on there causing this. Please take the motherboard out and check for corrosion!
If you’ve found it, then use isopropyl alcohol to clean it! If you are not sure, feel free to share some pictures with us!
Thanks!
Punteggio 0
Aggiungi la tua risposta
Ben McCarthy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 23
Tutti i Tempi: 257
