Salta al contenuto principale
An E-Cigarette vaporizer is a device used to heat a substance, such as cannabis or tobacco, to a temperature at which it releases a vapor that can be inhaled. It is a reusable alternative to traditional smoking.
My Yocan UNI Pro 510 vape battery blinks 5 times no matter what I do
How to fix it?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Hi @vape64454
You don't say what you've tried so here's a link that may help, in case you missed doing something
Also try tightening the 510 thread adapter as directed then back it off 1/4th a turn and try the cart again
Punteggio 0
1 Commento:
Thank you for your help. Have a nice day.
da
I have a lookah bear 510 thread battery that buy from 420buy.com online headshop, although not a yocan battery, but the problem and solution is similar.
Your yocan battery blinks 5 times is a poor connection problem that can be caused by dirty connection, misalignment, or faulty components.
Carefully clean the connector with a Q-Tip and Isopropyl alcohol (99%). Unscrew the cart a little at a time, but not too tight.
Adjust the connection plate using a paper clip to gently pull and push it back up to ensure both battery and cartridge are on the same level.
Punteggio 0
Aggiungi la tua risposta
510vape sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 124
Tutti i Tempi: 2,032
