Salta al contenuto principale
Accessorio Bluetooth che combina uno strumento di cattura per l'app "Pokémon GO" e un tracker del sonno per l'app "Pokémon Sleep"
My pokemon go plus+ got submerged in water
Hello. my go plus+ got submerged in water and after drying all the components. it wont turned on and i notice some of the SMD on white board are broken. so is it possible to get the type of the SMD? i thought replacing it should do the work
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi! Do you mean a SMD LED? Can you share some pictures with us?
Anyway, when it does have water damage, the best thing to do is to check for corrosion and clean it roughly with isopropyl alcohol! Make sure that all the corrosion is gone and everything looks clean again!
Hopefully after this it works fine. If a component need to be replaced, then it's for the best to replace it before you are going to try it again.
Not sure if there are any parts available for the Pokemon Go Plus.. When it's a LED you can probably find a replacement part as those are universal (you do need the right LED off course).
Punteggio 4
Aggiungi la tua risposta
DADANG sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 15
Ultimi 7 giorni: 26
Ultimi 30 giorni: 109
Tutti i Tempi: 1,741
