Salta al contenuto principale
Il mouse Anywhere Mouse MX è un mouse laser rilasciato da Logitech nel 2009. Il mouse si collega tramite un ricevitore Logitech Unifying ed è alimentato da due batterie AA.
I have broken a pad SW1 (again)
Hello!
I have broken my second Anywhere MX 1 mouse when replacing the SW1. The pad broke again near R6 (signal one, the ground is fine) and I was certain to not break it again. But it happened.
Is there any chance that anyone has got the schema or idea where the signal comes from? I would love to make a jumper and get my favorite mouse to work.
Immagine
Immagine
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta più utile
is this copper, can't tell with the flux
Immagine
Punteggio 1
4 Commenti:
I've edited my post and added photos of front and back. I've checked the C6, which appeared to be connected through a hole, but that side od capacitor appears to be a GND.
da
Nope - it is a PCB. The pad fell off. The only thing that is copper is the little hair trace that's left.
da
@makerbuddy have you got a multimeter
da
Yes I do, so I could tell that the trace goes to ground.
Besides I was working on it and today managed to catch the copper trace that was left from the pad. Used some copper wick as a new pad and everything works fine.
Besides that I still did not got idea where it goes! I've checked every component and signal points, but none of them was giving a beep in continuity test with multimeter...
da
Aggiungi la tua risposta
MakerBuddy sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 18
Tutti i Tempi: 319
