Horizontal Black/White lines, graphic card or screen problem?
It's a 2008 15" Macbook Pro with a Nvidia 8600M GT, and a C2D 2,4ghz.
Thanks in advance!
Questa è una buona domanda?
Thanks in advance!
After you check it with an external monitor, if the external shows the same problems, call Apple for a free logic board replacement for the Nvidia 8600 GPU issue. You may still be within the 4 year limit Apple set on this or be able to get an exception because it is so close. Here's Apples notice on this along with where and how to contact them: http://support.apple.com/kb/TS2377
+ Helpful information about the extended warranty coverage.
Connect to an external monitor if the lines are missing from there it' might be the controller board for the LCD. I'd replace the entire display as futzing with the controller board alone is a lot of delicate work...Once you get the back off the display you can find the right part number for the screen.
If this Answer is helpful please remember to return and mark it Accepted.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 7,260
