Why is my desktop beeping twice and won't display
my desktop beeps twice and won't turn on or display.
Questa è una buona domanda?
There are LED light flashing codes and beeping codes to help you:
In your case are any lights flashing? For example:
Possible Causes:
Processor thermal protection activated:
Things to do:
1. Ensure that the computer air vents are not blocked and the processor cooling fan is spinning.
2. Open hood, press power button, and see if the processor fan spins. If the processor fan is not spinning, make sure the fan's cable is plugged onto the system board header.
3. If fan is plugged in, but is not spinning, then replace fan.
Đã bao lâu rồi bạn ko vệ sinh máy, trường hợp này trước tiên bạn hãy tháo ram ra và làm sạch, và có thể phải pin cmos nếu đã nhiều năm rồi bạn chưa thay. Thân
TRanslation Vietnamese - English
How long has it been since you cleaned your computer? In this case, first remove the RAM and clean it, and maybe the cmos battery if you haven't changed it for many years. Best regards.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 121
