Salta al contenuto principale
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
I’m unsure what cable this is any idea?
I’m unsure what this cable is but it’s ripped my MacBook a1534 charges I feel the battery heat but not anything usual I doesn’t turn on or show the charging indicator
the last thing is my case on the corner is bent but the actual components are fine and working besides the cable is there a way to un bend it and is a small gap between the bottom case safe I don’t use it near drinks never have thanks
Questa è una buona domanda?
Punteggio 0
1 Commento:
@aadendonia12088 that looks like your Audio Board Flex Cable, Apple part number 923-01003. "is there a way to un bend it" and "is a small gap between the bottom case safe" will depend on how bend out of shape it is and how small the gap is. You can always try and bend some of that back or leave it if it does not impede the function.
da
Aggiungi un commento
2 Risposte
Looks like Apple's # 923-01003, Used for audio.
Punteggio 0
It appears the cable is damaged so you will need to replace it. The other folks have given you the parts info, here’s one source MacBook 12" Retina (Early 2015-2017) Audio Board Flex Cable
As to where the cable connects to on the logic board refer to Steps 23 thru 26 in this guide Sostituzione scheda madre MacBook Retina 2015 the image in Step 23 shows the cable already disconnected from the Audio board (finger pointing to it)
Immagine This cable connects the audio board to the logic board.
Prodotto
$14.99
Punteggio 0
Aggiungi la tua risposta
Aaden Donia sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 108
