My dsi wont read games
one of my cusans was playing with it but wane he gave me it back it will not raed games
Questa è una buona domanda?
Hey, the slot were the games go into is most likely damaged or needs to be cleaned. If you look in the slot, there is a door that needs to be lifted up and you can see the pins that read the game.
Shine a light into the slot and see if any of the pins are bent out of position or they have a green color corrosion over them.
If you see corrosion, then you can clean it with a nail file. Just be careful, so you do not bend the pins.
i might try it
well mine is a used one and it wont show
Hi my DSI had the same problem, so did my sister's but hers is fixed. All she did was shake her DSI and then clean the slot with a tissue. It didn't work for mine sadly
Oh yeah and what door do u mean
No I found a game out side and it has a dent in it the chip is clean but my dsi xl won't read it
Try spray compressed air in the slot. There may be dust bunnies inside.
Hello, I am a YouTuber who has this same problem. As soon as I find a fix it will be uploaded on my channel here.
Hopefully, when and if I upload the video it will help you out.
What door?I don't see a door
Try putting a clothing tag in the game slot alongside the game. Yes, it does work, but it may take a few tries. It seems like it would break it more, I know, but I swear this happened to me and this was my solution.
whats a clothing tag?
*sweatdrop*
Um...sometimes clothes have those tags that are connected by little plastic tabs. Just, if you keep trying to get the game to work, putting slight pressure alongside the game card helps.
I have borrowed a dsi and simply blew into the game slot
I think DSI causes issues sometimes in reading games. You have to try it again and again and hopefully, it will help.
Ultime 24 Ore: 6
Ultimi 7 Giorni: 54
Ultimi 30 Giorni: 274
Tutti i Tempi: 33,036
Hi i have the same problem . I don't have an sd card and i put wifi and thats when the games didn't work anymore. I tried everything and it didn't work. I even formatted settings and everything still didn't work
da Celine
