Salta al contenuto principale
L'aggiornamento di marzo 2015 del MacBook Air 13" di Apple ha processori di quinta generazione Intel Core i5 e i7, risultando in una migliore performance e maggiore vita della batteria.
MacOS factory reset. Boot loop/ failure to mount EMG after reinstallOS
I have wiped the disk. Repaired the disk. Nothing. I have tried everything. The mac worked literally prior to me wiping the disk and trying to reinstall the sierra OS. It was fine. Just I wanted to factory reset it and once I went through that process the installer log states.
" Couldnt mount base system dmg failed to mount outer dmg."
it also said " no app was found with bundle id com.apple.InstallAssistant.Sierra to upgrade to 12.6.03"
No naticve mechanism to verify installESD.dmg
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta più utile
@stopstalkinw834
Hold On!
This is a common issue as Apple uses signed OS installers which with older releases we often encounter the key has expired. You need to get a fresh OS installer file and copy it to a USB thumb drive which you need convert into a bootable installer.
Get the newest macOS your system can support from here How to download and install macOS then follow this to create a bootable installer Create a bootable installer for macOS
Punteggio 1
2nd edit - Listen to Dan!
As someone who used to work at an Apple Store, I would bring your device into the store if it is accessible. OS reinstalls were common at my job. The turnaround time is long, but even if they can't get it done the same day, they might be able to give you some advice that allows you to fix it yourself.
Edit - if you post some pictures of the screen and errors here, it might help determine your best course of action without an Apple Store excursion. If you do go to the store, I recommend going early and/or making an appointment.
Punteggio 0
Aggiungi la tua risposta
Stop stalkin weirdo sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 1
Ultimi 30 giorni: 12
Tutti i Tempi: 335
