Install OS on 2012 iMac headlessly?
I came across a 2012 iMac (A1419) with a busted display. I removed the LCD panel and the cable altogether, connected it to an external display using a mini DP -> HDMI adapter and it booted up and output to the external display. However, the previous owner didn't wipe the hard drive so I'm stuck at the login screen. And I eventually want to run Linux on it heedlessly.
So I burned a Catalina recovery USB and tried to boot from it. I used a USB keyboard and pressed and held option key when powering up. The USB stick should be good. I can boot from it on a MacBook. However, it looks like the initial screen is not output to the external display so I have no way to install the OS.
Has anyone succeeded in doing this? If so, what's the trick? Thanks.
Questa è una buona domanda?
4 Commenti
Can you hear anything from the computer? Such as the HDD or the computer speaking for VoiceOver?
da TeHKy_SS
The hard drive is spinning (it’s an old magnetic hard drive, not an ssd, haha). But otherwise there’s no sound. It’s been a while since I installed macOS from scratch. But does voice over come in automatically?
da Deling Ren
You can see the boot options screen on the external monitor, correct?
da TeHKy_SS
No, I can’t. The first thing I see on the external monitor is the login screen of macOS. This seems to be different from MacBook where the display is mirrored from the very beginning.
da Deling Ren
