Salta al contenuto principale
Una Roku TV da 32" rilasciata da TCL nel 2018.
Volume issues down and up at any time
Volume issue down and up at any time
Questa è una buona domanda?
Punteggio 0
1 Commento
Hi, it would be helpful if you can be a bit more specific like:
“it does it by itself”
“Volume doesn’t change going up or down”
“Other symptoms”
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
@bekaluyitbarek couple of things you want to try. First you want to go into your audio settings. There should be a "Advanced Settings" area. Click on that and then turn the "Auto Volume Control" off.
Next remove the battery from your TV while it is turned on and see if the volume has normalized.
Let us know what you find out.
Punteggio 0
Aggiungi la tua risposta
Bekalu Yitbarek sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 17
Ultimi 30 giorni: 33
Tutti i Tempi: 529
