Salta al contenuto principale
Il Sega CD I, noto anche come Mega CD I (in Giappone) era l'unità CD originale Sega rilasciata nel 1991.
Capacitor C47 On the Main Board - Can it Be Mounted on the Underside?
Immagine
Immagine
Immagine
Immagine
Immagine
Hello:
I have received a Sega CD Model 1, and it looks as though there was an attempt at capacitor replacement previously. C47's entire top of board area has been decimated; no trace exists, let alone the pads for the SMD. However, I am not confident in my ability to pinpoint where (if anywhere) the cap could be bridged on the back of the board.
Does anyone know if this is possible, or is this board simply shot?
Thank you!!
Questa è una buona domanda?
Punteggio 1
1 Commento
@thomaswile give this a good cleaning. Soldering iron, flux and a desoldering braid should clean most of that mess off. After that use some isopropyl alcohol and a cotton tipped applicator to clean that some more. Let's see the bottom of it.
da Condividi
Aggiungi un commento
2 Risposte
Risposta più utile
Hi @thomaswile
Post some images of the board in your question so that the problem can be seen Here's how on ifixit. Aggiungere immagini ad una domanda.
Chances are that as it is an smd component it won't connect through to the underside of the board as would through hole components.
smd = surface mounted device, so unless the pads that it was connected to were connected to traces that have a link/pin connection through to the underside of the board to other traces, there's not much you can do.
Punteggio 3
4 Commenti:
Hello! I apologize for the delay. I have added the photos that you requested. Word of warning; it's a massacre...!
da Condividi
The last picture was good nice image of the damage. Can you upload one zoomed out a slight fraction to show slightly more of the board around it .
da Condividi
Hi @basementdax I added two new images, zoomed out a bit front and back both. They should be the top-most images.
da Condividi
@basementdax @oldturkey03 I have a big roll of copper tape now in my arsenal...would that help at all in repairing any of the damaged traces?
da Condividi
@thomaswile as already addressed, we need to see the complete board, both sides. Looks like the traces could be on the bottom side since the VIA's are right there.. Make sure that you post images that are well focused and large enough. Also, there is a variety of different boards out there, hence the importance of good images. It looks like it needs to go to IC15 pin 32
Update 09/09/2024
@thomaswile here is what it is supposed to look like
Immagine
Immagine
As you can see, (the images are large enough for you to zoom in) the traces from C47 are the Vias connecting to C13 on the underside.
To answer your question "Can it Be Mounted on the Underside?" The answer is, Yes. All you have to do is to clean the mess on top, check the traces and if they are okay, you can solder the capacitor on either side.
Your board may not be as damaged as it looks. Once all the old solder and debris has been removed, you may just be surprised by how little damage there actually is. Give it a try. After all
Repair is War on Entropy!
Punteggio 2
20 Commenti:
Apologies; I have added more photos. I am very new to a lot of this and am sorry for misunderstanding any prompts.
da Condividi
@thomaswile it's absolutely no problem. On here, you don't ever have to worry about things like that. Everybody is welcomed at iFixit. I do not see any further traces on the bottom side. I wonder if they come from C13 to the Via of C47. Let's see if we can find out.
da Condividi
Agreed. The board doesn’t look that bad . Just don’t bridge capacitors, like ever!.
Flux and solder braid should clean it up. Then clean with ipa, then flux and tin the pads. If pads are damaged missing show us pictures after clean up .
da Condividi
@oldturkey03 Thank you!!!
da Condividi
@basementdax Sadly, that is actually the board after clean-up...no pads, no traces...nothing.
da Condividi
Mostra 15 altri commenti
Aggiungi la tua risposta
Thomas sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 19
Tutti i Tempi: 766
