Salta al contenuto principale
L'aggiornamento di marzo 2015 del MacBook Air 13" di Apple ha processori di quinta generazione Intel Core i5 e i7, risultando in una migliore performance e maggiore vita della batteria.
Hi there, Is it possible to upgrade a early 2015 13inch MacBook Air ra
Hi there, Is it possible to upgrade a early 2015 13inch MacBook Air with retina display to 2TB NVMe SSD
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Yes, the Blade SSD can be swapped out, here's the guide Sostituzione SSD MacBook Air 13" versione inizio 2015 as to what to use your system offers a custom Apple PCIe 3.0 x4 interface. You can use a pin compatible drive from OWC or Transcend or use an adapter to convert the custom interface to a M.2 interface to plug in an M.2 drive. Depending on your use you may encounter issues with some of the M.2 drives so be careful on who’s you use and of course backup often.
Punteggio 0
I recommend to use a Sintech Adapter & a Samsung 970 EVO Plus SSD (With Firmware 2B2QEXM7 or 4B2QEXM7 and you shouldn't have any issues. I have been running this setup for over a year and so far it has performed perfectly.
Punteggio 0
Aggiungi la tua risposta
Abdallah Seif sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 34
Tutti i Tempi: 149
