replaced inverter cable and inverter still no backlight
Hi, I've replaced the inverter cable and the inverter but I still have no backlight.
I did inadvertently try and put the cable into the motherboard socket upside down - is it possible i've damaged the contacts in such a way they no longer make contact with the cable?
I didn't really force it before I figured out it was upside down but who knows..
The fault was definitely with the cable originally - if i moved the cable the backlight would go but eventually it did stop working even when I moved the cable.
Any advice gratefully received.
cheers
Nigel.
Questa è una buona domanda?
2 Commenti
nigelgardiner, besides the great answer from Stefano Gigante, also check on this question Screen *extremely dim* on boot, external display works great and read the answer given by "Alberto": " on the logic board there is a fuse that supply's the voltage/ currant to the backlight circuit...its F9800.Its located on the board near the botom of the left fan on the component side of the board.(same side that has the cpu and gpu on it). new model had then on top near the led display cable connector is black white dot. The fuse is a smd and its white with just a dot on it.get your multimeter and if its open circuit thats you problem." Just remember that it is a 2A fuse in an 0402 package. May be this will help, good luck.
da oldturkey03
Good point. I too checked my logic board when my backlight was acting up. But then I just got a new inverter and cable.
The occurrence of capacitor failure in that area is, fortunately, negligibile. The first things to go are the cable (that bends itself at the hinges: I got a "gnarled" Airport cable, as it makes the same route) and the inverter.
Usually follows the CCFL, whose inherent lifespan is doesn't reach two digits.
da Stefano Gigante
