Salta al contenuto principale
Lanciato sul mercato nel 2020 con SOC Snapdragon 720G. Venduto in India come Note 9 Pro Max.
Allegedly Stuck in 2G.
Hi all.
I'm a trucker so i use my device constantly and always with data on. After a light incident in which the device fell on the truck floor my connection is terrible.
When I say terrible i mean it works fine sometimes (i should say under certain antennas) and has no data signal in other areas.
My ISP supposably did an extensive check and after 2 weeks the answer was my device is stuck in 2g, even though i sometimes have normal service.
Troubleshooting I have done so far is I took a new SIM card and even tried another ISPs and i had no change.
Should I try to change my data chip?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
go to settings and check for sim settings and from there select your sim and then if you check you can see a setting called preferred network go there and select the required network option
Punteggio 0
Aggiungi la tua risposta
xxdwbxx sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 9
Tutti i Tempi: 227
