Salta al contenuto principale
Smaller, thinner, quieter model of the Playstation 2 (SCPH-700xx) released by Sony in September, 2004.
Why does my PS2 slim have a blinking red light?
I connect power and I get a solid red light. Then I press power and it turns green for like a second or 2 then it starts blinking red. Anyone know why?
Pictures:
Questa è una buona domanda?
Punteggio 0
5 Commenti
Hi Francisco!
Do you have the PS2 Slim with the internal power supply or the one with the external power supply?
If you are not sure, could you share a photo with us (back side where the connectors are).
Thanks in advance!
da
Im unsure but ill add a photo of the back side and the adapter i use
da
Great! Looking forward for the pictures! Thanks!
da
I just posted them. 😁👍
da
Thank you! I’ll write an answer!
da
Aggiungi un commento
1 Risposta
Risposta più utile
Alright regarding the photo’s and comments, this is most likely caused by a faulty power supply.
It’s an external power supply and replacing this is very easy (as the PS2 Slim does not need to be disassembled).
The power block you have there is not the original one. I recommend to replace it!
Part: https://www.ebay.com/itm/176206189545?it...
Just swap the power block and you should be all good again!
Good luck and let us know how it goes!
Punteggio 1
2 Commenti:
Okay Ill try this and let you know. Thanks
da
Alright! Thanks! If you have any questions, just let us know!
da
Aggiungi la tua risposta
Francisco Vasquez sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 22
Ultimi 30 giorni: 69
Tutti i Tempi: 1,691
