Salta al contenuto principale
La Nintendo DS Lite è stata rilasciata nel 2006 subentrando alla Nintendo DS. Lo smontaggio di questo dispositivo è semplice, il che ne rende facile la riparazione.
316 Domande Visualizza tutte
Domanda Chiusa
Why does my DS Lite's top LCD only display white?
I've had my ds lite for about 2 yrs, and when I was playing a while back, a piece of hinge from the side of the LEADS fell off. The ds lite hinge wouldn't hold, it would just flop back. Then the top screen started to put lines in the screen. Then, after that, the screen would turn white, unless i held the screen at a certain angle.
Now, It is only white, no matter what angle i hold it at. The touch screen works fine. all buttons are fine. not bricked. Help?...
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Broken ribbon cable, get a new case and top screen.
Punteggio 0
You don't need to get a new case if it's not broken, you can disassemble the DSL with a Phillips #00 and a TriWing driver. There are two possibilities how the problem could be occurred. First, and that's the one cheaper and easier to fix, the ribbon cable from your top screen is broken and you just need to change the top screen. Or, second, the flap attaching the ribbon cable to your logic board is broken. In that case you have to change the logic board, but these are about 50$, so it would be cheaper and easier to buy a used DSL from eBay etc.. If you want to replace the screen (or the mainboard), maybe it would be an idea to buy a broken DSL with a faultless screen or mainboard, disassemble it and replace the broken parts with the intact ones. Somehow or other, repairing a DS isn't as difficult as it looks like, you just need sure instinct. Give it a try.
Punteggio 0
2 Commenti:
Reply to tragosso--
Is there a way to find out what one of these 2 problems are wrong with the DS.
Thanks!!
-gabagababaunites
da
This is the same thing that happend to me and other good tips that can help
da
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 3,022
