Salta al contenuto principale
Won't boot OS 10.4 install except Disk Warrior - display bad?
Display has 23 vertical columns with blue ladders. Won't boot into OS. 10.4 or install disk but will get to first install screen so I can run disk utility to find specs and do clean-up.
I can run Disk Warrior successfully but display has vertical hash marks even on the Apple start-up logo.
Any ideas on fixing? Costs for parts?
Has 10.4.3 installed.
PowerMac 12.1
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Here are two very good answers, one is mine: There are vertical lines in my screen..
Punteggio 2
2 Commenti:
Loosen the screws on the bottom edge of the screen and remove the back. Examine the cans (capacitors for corrosion and/or bulging.
da
Yes, probably bad logic board.
da
Aggiungi la tua risposta
Gary G sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,348
