I need to replace the top case
My MBP is an A1150. I heard that a Top case from an A1211 could be compatible. Is this true?
Questa è una buona domanda?
The A1150 is a core duo model and the A1211 is a core 2 duo. The parts that Apple specs to use as a top case for these models are different. Most likely you can't use the other top case as the wiring will be different between the two models.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 570
