Salta al contenuto principale
Guide di riparazione e smontaggio per adattatori di ogni tipo.
Mac ADC to DVI Adapter Power Failure - Repair?
For the old ADC Cinema Displays to work with many computers there is an adapter. Apple no longer sells them, and they are expensive. What happens about every 2 years is the power supplies go dead. I would like to know if anyone has repaired these by:
1. Replacing the blown component, or, my first choice,
2. Has anyone tapped in a 24v/5 amp power supply
Thank you so much
Questa è una buona domanda?
Punteggio 3
1 Commento
any chance you could post an image of the logic board with the bad component?
da
Aggiungi un commento
2 Risposte
Soluzione prescelta
SlotcarBob, take a look at this site. It will provide you with a pinout of the adapter as well as give you direction in how to build your own adapter. Including the power supply. hope this helps, good luck.
Punteggio 3
1 Commento:
Great research to solve a recurring problem. +
da
it is best calble to send infor
Punteggio 0
Aggiungi la tua risposta
SlotcarBob sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 17
Tutti i Tempi: 2,127
