[Your Samsung Galaxy J6 is not able to sense any nearby device's, it goes for Bluetooth, hotspot, Wi-Fi.]
POSSIBLE PROBLEMS WITH YOUR DEVICE👇
- Invalid or erased address
* The Wi-fi/MAC or Bluetooth address might have been erased or become invalid.
- Insufficient app permissions (its true)
* The Wi-fi/Bluetooth might be force closing due to insufficient permissions to launch certain system level apps.
- Corrupted APK's or Files (not virus)
* The Wi-fi or Bluetooth system app's file might have got corrupted or missing.
- Third party app interference
* Third party that call themselves as Wi-fi or Bluetooth management apps might be interfering with your system. Example: Babel Fonts apk.
* This is a very common issue, your OS might have got some minor issue (not to worry about) (SOLUTIONS ARE GIVEN DOWN)
* If no Bluetooth or Wi-fi devices have been detected within the timer set, your Bluetooth or Wi-fi automatically goes off. (SET IT TO A REASONABLE TIME)
* It might happen that the problem lies under the transmitter or receiver OR The I.C (integrated circuit) or the motherboard might have got damaged or are just dusty.
POSSIBLE SOLUTIONS TO THE GIVEN ABOVE PROBLEM IN A SEQUENTIAL MANNER👇
- Check your Bluetooth and Wi-fi / MAC addresses
* Re-write them if empty
* This helps clear temporary OS issues
- Enable GPS / Location access
* You might have disabled them on system level. Try enabling them as they are way more crucial and just more than Google Map. HERE IS HOW YOU DO IT -> Settings -> Location access (REMEMBER TO ALLOW YOUR LOCATION ACCESS TO APPS THAT ARE USED TO USE THEM AND NOT SOME FAKE AND UNWANTED APPS.)
- Uninstall third-party apps
* Uninstall all third party Bluetooth and Wi-fi management apps you have got.
* Go to settings -> Apps -> All -> Press menu button -> Reset app permissions
* Go to settings -> General management -> Reset -> Reset network settings. This will reset all the Wi-fi and Bluetooth connections on your phone.
- FACTORY RESET✨ (🎗️THE MOST RECOMMENDED AND THE MOST HELPFUL OF ALL🎗️)
* If none of the above solutions work then the only left and the best solution (because it fixes everything at one click) is FACTORY RESET, don't worry because it's a sketchy and scary word for some people. But this process only takes about 1-2min and about more 10 - 15 min for final recovery and syncing.
Votato
Annulla
Punteggio
0
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
