Why it's not charging when I plug it?
why it's not charging when i plug it?
Questa è una buona domanda?
Hi Yusme, I hope your having a great day!! Let's have a look on your problem. It looks like your RIPPA RA903B Controller is not working.
You can do some simple stuff to get your problem fixed if its not a major one:
1.) Check the Charging Cable and Port
2.)Reset the Controller:
Remember that third-party controllers may have varying compatibility and charging behaviors. If you’ve tried all the steps above and the issue persists, consider reaching out to the manufacturer’s support or checking community forums for specific solutions related to this controller model.
Additionally, I found a teardown guide for the Rippa RA903B Controller. It provides detailed instructions on opening the controller, which might be helpful if you need to inspect the internal components. However, proceed with caution and only attempt this if you’re comfortable with disassembling electronics.
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 38
Tutti i Tempi: 1,009
