Salta al contenuto principale
Il terzo aggiornamento del controller wireless dell'Xbox è stato rilasciato a novembre del 2020, insieme all'Xbox Serie X ed S. Il controller è anche compatibile con i precedenti modelli di console Xbox One e i PC.
How can I repair my drifting left stick
I never had a problem in my life with drifting stick but the time has come. So any advice how can I fix this problem?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
The answer is to either go around is with a q-tip and some isoprypl alchohol rub the q tip around the joystick hole
If that doesn't work try to take an air blower to it to try to take out any dirt and debris
If all else fails you can replace it with this part however be aware that it does require soldering
Immagine Replace one controller joystick compatible with an Xbox Series S or Series X controller. Fix issues like drifting or an unresponsive joystick.
Prodotto
Xbox Series X/S Controller Joystick
$14.99
Punteggio 2
You could either try cleaning the potentiometers in the stick with something like BW100 or isopropyl alcohol or just replace the stick. It kinda depends on the severity of the drift if cleaning it would work or if it needs a replacement, so see what works and I hope one of these ways fixes it.
Have a great day!
Punteggio 0
Aggiungi la tua risposta
Michał Długosz sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 16
Ultimi 7 Giorni: 89
Ultimi 30 Giorni: 390
Tutti i Tempi: 1,887
