Hi @therocker9987,
Your problem maybe a faulty connection between the screen and the keyboard. It can come from particles in the hinge (explaining the crackling noise when moving).
You can access and clean the hinge by opening the keyboard assembly, which is much simpler and less dangerous than the opening of the screen.
If cleaning isn't enough, with the hinge disassembled, I think you can find spare connectors on the web and change the faulty one with a new one and re-assemble the hinge.
You can use this tutorial to open your keyboard. You may have to remove the battery and all the component to access the screws of the hinge (2 groups of 3 black screws + connector screws, if I remember well).
With the hinge separated, you can disassemble each part one one by and remove the surface connector from the hinge. You can clean it with isopropylic alcohol, contact cleaner, and remove all the dust particles from the hinge part. I advise you to make a visual inspection of the connector which is composed of dozens of small cables taped together. It can be very weak and sensible to puncturing ...
Make one more try with the clean connector, if it doesn't work, think about buying a new one.
Hope it helps :/
Nestor
Votato
Annulla
Punteggio
0
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
