Can't take the rear panel off
My iPhone fell and the rear panel broke, I tried to replace it but the screws rotate and won't come out (I've taken them off before). any help?
Questa è una buona domanda?
Assuming you are using the correct screwdriver, you could try to take the screws out with the charging port facing downwards, so gravity can help. Even if you only get the screw out a bit, you could try to add tension between the screw and the frame with a very thin object. If all of that doesn't work or is too much of a hassle, you could always just break the glass and pry it off, but I wouldn't recommend it. More as a last resort.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 53
