Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
No pressure contact next to battery connector
Description:
While attempting to resurrect/troubleshoot a broken/damaged used iPhone 4 GSM I just purchased (screen is blank), I noticed after removing the back panel and removing the battery connector there is no pressure contact present in this phone. The owner prior to me did have the front and back pane replaced with a color scheme set. Whether or not there ever was a pressure contact in this phone I am unsure.
Question:
So, my question for you guys is this: should there be a pressure contact present in this iPhone 4 GSM (A1332), if so, where do I get one? Thanks in advance for any direction with my above concerns.
Respectfully,
Brian Davis
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
My iPhone 4 has a Pressure contact, but i never took mine off, so i dont know what issues it causes when its not attached.
its apart of the antennae system that receives GSM RF's (if your AT&T) and Bluetooth.
if your looking to buy one: Here you Go
Don't think that just because you have great cell phone signal, you dont need that pressure contact. That piece also receives the Bluetooth radio frequency.
Punteggio 0
2 Commenti:
Hmm...ok, thanks for your comments! (:
$20! That seems awfully high so I did some prowling on my own. I found one at a much more inexpensive price...about 20 x's cheaper (: here you go, for anyone else in the future needing one:
http://www.parts4repair.com/iphone-4-pre...
Sells for $1.33 (:
Respectfully,
Brian
da
Hi, did you see any improvements after putting the contact?
da
Aggiungi la tua risposta
Birdmanbrian1 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,468
