My camera won't take pictures
Whenever I try to take a picture, it gives me an error, saying:
Err99
Shooting is not possible. Turn the power switch to <OFF> and <ON> again or re-install the battery.
Questa è una buona domanda?
Err99
Have you tried to see weather it works plugged in to power? (If you can do this with the camera, of course)
After doing some research, Error 99 seems to mostly have to do with the shutter. (Error99 basically means there is a problem with the camera, but the device is not sure what the error is) Try to see if you can lock up the shutter for cleaning. If that does not work, then you might want to try to further investigate the shutter.
Good luck fixing your camera!
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 14
