Salta al contenuto principale
Tecno Spark 6 Air mobile was launched on 30th July 2020. The phone comes with a 7.00-inch touchscreen display offering a resolution of 720x1640 pixels and an aspect ratio of 20.5:9. Tecno Spark 6 Air is powered by a quad-core MediaTek Helio A22 (MT6761) processor. It comes with 2GB of RAM. The Tecno Spark 6 Air runs Android 10 and is powered by a 6000mAh battery.
Why is my phone doesn't vibrate when ringing?
My phone has stopped vibrating by its own when people call
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
3 Risposte
Risposta Più Utile
To make your TECNO Spark 6 Air vibrate, you can use the “Vibrate on touch” setting in the “Sound & vibration” menu of the “Settings” app on your phone. Here's how to do it:
Open the “Settings” app on your phone.
Scroll down and tap "Sound & vibration."
Scroll down and tap "Vibrate on touch."
Turn on the “Vibrate on touch” toggle switch.
Test the vibration function by tapping the screen or pressing a button on your TECNO Spark 6 Air. Your phone will vibrate.
Punteggio 1
Verify that the "Silent Mode" is off: If your phone has a "Ring switch", move the switch forwards so that the orange bar is hidden. You can also use "Control Center" to check if the "Silent Mode" is turned on.
Punteggio 1
First check the settings, if setting are okay then maybe you need to change the vibrator.
Punteggio 0
Aggiungi la tua risposta
Dagim Solomon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,074
