Salta al contenuto principale
La versione allargata del decimo telefono di Samsung della sua serie top S, presentato nel febbraio 2019. Dotato di Android 9.0 (Pie).
Mobile screen is cracked, need to change battery back panel came out
Need to change battery. Back panel glue came out. And battery got swellen
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
@kalam86420 easy enough ;-) Use this guide Sostituzione batteria Samsung Galaxy S10+ for the repair and you can get the battery from here Galaxy S10+ Battery (depends on where you reside). Due to  shipping regulations, we can only ship lithium-ion batteries to physical addresses inside the contiguous United States (lower 48 states) via Ground shipping methods. We cannot utilize Air shipping methods for shipments containing batteries. If you reside outside the USA you may need to find a supplier closer to your geographic region.
The first guide also shows you how to remove the back cover. If you need to replace it you can get that one from here Galaxy S10+ Rear Glass Panel/Cover and the adhesive to keep it secured is available right here Galaxy S10+ Rear Cover Adhesive
Repair is War on Entropy!
Immagine Replace a dead or malfunctioning model EB-BG975ABU battery compatible with a Samsung Galaxy S10+ smartphone.
Prodotto
Galaxy S10+ Battery
$19.99
Immagine Replace the custom cut adhesive film that secures the outer edge of the rear cover panel compatible with the Samsung Galaxy S10+ smartphone model #G975U, G975F/DS.
Prodotto
$6.99
Immagine Replace a broken or scratched rear panel on a Samsung Galaxy S10+ with this new blank aftermarket rear panel.
Prodotto
$16.99
Punteggio 0
Aggiungi la tua risposta
kala m sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 27
Tutti i Tempi: 229
