Salta al contenuto principale
Il Logitech G502 Lightspeed è un mouse da gaming wireless che condivide la maggior parte delle specifiche con il suo corrispettivo cablato, il G502 Hero. Numero di modello MR0076. Rilasciato a maggio 2019.
Scroll wheel doesn't respond.
I used 70% isopropyl alcohol to remove fur on the inside of the wheel, but after waiting for the alcohol to dry, the scroll wheel started to respond less and less over time until now, where it does nothing.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Why use alcohol at all ??? In the future why not just use your fingers and small tweezers to pull out the hairs?
Another very important point is that 70% isopropyl alcohol is for disinfecting NOT electronics, as it has to much water in it often with minerals which leave deposits which can short electronic circuits. 99% or very close to that is preferred and is available at electronic component supply shops.
You may also have to wash the area with pure distilled water available as pharmacies. Make sure it is completely dry before using mouse again as water will short the electrical circuits.
Punteggio 0
Aggiungi la tua risposta
Cadfg sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 9
Ultimi 30 giorni: 66
Tutti i Tempi: 1,096
