Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Domande Visualizza tutte
Unable to send e-mails but can receive them?
Any suggestions on how to fix this would be gratefully received.
Many thanks,
David
davidjbayliss@sky.com
Questa è una buona domanda?
Punteggio -1
1 Commento
I don't know the answer to this, but as a heads up generally we try to focus on hardware questions, instead of software ones. http://www.ifixit.com/Answers/About
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Sounds like an authentication problem. Double check your settings.
Depending on where you are attempting to connect for e-mail, they may have a suggestion for their SMTP Authentication requirements.
Good luck! :)
EDIT: If the Sky.com is the e-mail you are attempting on the iPhone, then check this out: http://www.sky.com/portal/site/skycom/sk....
Punteggio 1
Aggiungi la tua risposta
David J Bayliss sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 592
