Salta al contenuto principale
Repair information for the Brother MFC-J6920DW wireless, multifunction inkjet printer. Model number: MFC-J6920DW. First available on Amazon in September of 2012.
Scan error - PROBLEM SCANNING SOMETHING WENT WRONG PLEASE TRY AGAIN
why does the scanner scan/take all the documents through the feeder but then give an error message - PROBLEM SCANNING SOMETHING WENT WRONG PLEASE TRY AGAIN . It happens sporadically and can happen for 1 or more pages
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I would clean the feed rollers as over time the paper dust makes then slick so they fail to transport the paper through the feeder. Sometimes the rubber looses its tackiness as well which may require replacement.
Punteggio 0
1 Commento:
Thanks I have also been told it could be a software issue.. I will disconnect the printer and reinstall to see if this fixes the issue
da
Aggiungi la tua risposta
Donna Halpin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 274
